HP Envy Sleekbook LA-8661P Conversion Discrete To UMA
Founder
conversion of HP Envy Sleekbook can be done , only by removing a component on the motherboard. It does not need to remove graphic chip. as mentioned before , after conversion the system turns to use Intel graphic. This system also from graphic type model laptop which for some cause , graphic chip does not work then it has to removed or replaced with alternative one.
motherboard model: QAU30 LA-8661P
  • HP Envy Sleekbook LA-8661P Conversion Discrete To UMA.rar
